Thread: NJ inspection
Old 08-02-2009, 10:37 PM
jlb454 jlb454 is offline
They are really big on items that rub, even if they're wrapped in stainless,
Throttle cable wasn't tied down to their approval,
The fuel line and positive wire to the batter can't be on the same side of the frame.
The oil line (we have an aux oil cooler) which is braided in stainless was rubbing against the block.
Our bottom radiator hose went under the frame. There is NO way but to route it that way. We argued that the oil pan would hit way before it took a radiator line so they let it go.
All the items could have taken a half hour to fix. Our original inspection was July 1st, we called the day after to reschedule and the earliest they could take us was on the 31st. The things we thought they'd bust us for...our tires stick out a good inch all the way around. They didn't check lights, brakes, turn signals, indicator lights, high beam, or anything that required a key(never gave them the key).
