Old 08-03-2009, 08:05 AM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Default Size of fuel filter?
Would like to know what the rest are using. What size, type and what micron filtering? I'm using a Barry Grant 185 pump and have tried 3 different in line filters from Jegs, Summit and Earls similar to these:
http://www.summitracing.com/parts/SUM-230101/
Filter is inline before the pump.
They tend to start plugging up after about 500 miles or so and then I lose pressure from the pump (normally 7lbs down to 1lb) When I pull them apart they are dirty so I'm thinking I need more surface area.
If I can get it to fit, will be trying to put this in place of the others:
http://www.summitracing.com/parts/SUM-G1503/
Also I don't buy my gas from the same station everytime and I watch for the refilling tankers.
Thanks
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
