Old 11-27-2001, 06:00 PM
Ratsnake Ratsnake is offline
Cobra Make, Engine: None yet
Clois,
In case you're still not having any luck with your clutch problem, I had the same problem with mine after I pulled the trans for some work. The only way I could get mine fully bled was to gently pressurize the reservoir with air from my compressor and opening the bleed screw. Be sure to monitor the fluid level in the reservoir and not let it run dry.
Good luck!
Tom
