Originally Posted by Argess
I run 28 Deg intial and 38 max with my non-vacuum dist. And I have run it higher with no issues.
A vacuum unit would be better as I could then set the intial around 16 (for my cam at max power) and the vacuum for 38 Deg at idle (best idle pulling 20 in Hg @ 38 @ 800 rpm).
WOW 28 intial is extremely high. Your right 16 to 18 would be much better.
