don't know what your specs are but for a 427 using specs for a healthy 406ci (3.80x4.125) exhaust program shows
--- Single Primary Pipe Specs --- for 427.650 CID from 4600 to 7100 RPM
Diameter= 1.873 to 1.998 Length= 29.9 to 32.7 inches long
--- 2-Step Primary Pipe Specs ---
1st Dia. inches= 1.873 Length= 15.0 to 16.4
2nd Dia. inches= 1.998 Length= 15.0 to 16.4
--- 3-Step Primary Pipe Specs ---
2nd Dia. inches= 1.998 Length= 7.5 to 8.2
3rd Dia. inches= 2.123 Length= 7.5 to 8.2
--- Header Collector Specs (Conventional Straight Tube) ---
Diameter= 3.422 to 3.672 Tuned Lengths= 17.2 best and also 8.6 or 34.4
--- Header Collector Specs (Megaphone or Diffuser Cone Shape) ---
Diameter= 2.922 taper to 3.922 Megaphone/Diffuser Length= 17.2 inches
Best HP/TQ Tuned Collector Lengths= 17.2 , 34.4 , 68.7 , 137.5 inches long
Worst HP/TQ Loss Collector Lengths= 25.8 , 51.6 , 103.1 , 206.2 inches long
Note-> all Pipe Diameters are OD and based-off .0625 inch Pipe thickness
---- Primary Pipe's Harmonics ----
1st Harmonic = 131.8 inches long ... typically never used
2nd Harmonic = 50.0 inches long ... longest recommended
3rd Harmonic = 29.9 inches long ... highly recommended , best Torque Curve
4th Harmonic = 20.8 inches long ... shortest recommended
5th Harmonic = 15.7 inches long ... typically never used
6th Harmonic = 12.3 inches long ... typically never used
7th Harmonic = 10.0 inches long ... typically never used
8th Harmonic = 8.3 inches long ... typically never used
---- Collector's Harmonics (includes Intermediate, Muffler , TailPipe) ----
1st Harmonic = 137.5 inches long ... longest with Mufflers and TailPipes
2nd Harmonic = 68.7 inches long ... longest recommended with Mufflers
3rd Harmonic = 34.4 inches long ... more bottom-end Torque
4th Harmonic = 17.2 inches long ... highly recommended , best Torque Curve
5th Harmonic = 8.6 inches long ... reduced Torque , more top-end HP sometimes
6th Harmonic = 4.3 inches long ... reduced Torque , not recommended
