Thread: 10" springs
Old 08-10-2009, 11:09 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I think you are pretty much right on the spot for the springs if you are running a small block. If you are running an FE then you might want to go up to a 450-550# springs. The larger number would be if you are racing and that is just a guess because you would really need to have the weight at all four corners to determine the correct spring rates if you just wanted to go neutral.
"Let's roll"
"Be part of Something Good
