Old 08-12-2009, 05:55 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Wire the LED as a parallel circuit to the switch.
There should be power going to the switch. You toggle the swwitch and then power continues to the Accusump. Have that circuit also connect to the positive side of the LED. Ground the other side of the LED. So, everytime you toggle power to the Accusump, you will toggle power to the LED.
