It's possible that the car has the pin drive length lower a-arms, and the stock length upper a-arms to cause this. My coupe still had quite a bit of thread left in the upper arms with -1degree of camber and 5.5 degrees of caster, but I'm also running power steering, so this spec works great for me.
Maybe a call to FFR with the length measurements of each arm?. Drastic measure, cut down the threaded sleeve on the upper a-arm? I can check the stock length on the upper and lower arms later tonight on my coupe to give you the stock bolt on wheel length if needed.
Scott
FFR3489 372w, Paxton1200, 475+rwhp & 431 rwtq at 6#boost..now running 14#boost
FFR Daytona Coupe #273, 331 stroker
