Old 08-15-2009, 06:58 AM
mikeforte mikeforte is offline
Hi,
Any high peformance engine with high compression, or power adder I tell to set gap at .035. It's best to get the spark than a misfire. Large plug gaps also burn out ignition wires. You can see wires that are like new but burned near the cap. They have a brown tinge to them.
Large plug gaps are for low performnce emissions engines.
I remember in the late 70's misfires at the rotor shorting to the distributor shaft....
Think of it as a .22 hit is better than a .45 miss...
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
