Old 08-15-2009, 02:31 PM
Argess Argess is offline
Originally Posted by Bobcat View Post
You mentioned engine rpm dropping under hard braking ... you might try running a rubber line from the front vent to the rear vent of the carb(s) , but drill about 6 to 8 holes in the top of the line at the high point .
LOL...I was thinking of doing exactly that, although with my luck lately, the rubber hose will come off and dissapear inside the manifold.
Interesting what you said about 38 degrees giving you the best idle as my engine builder just dynoed a 482 with tunnel port heads and had the distributor locked at 37 degrees . He made over 700 hp and said he had a smooth idle at 700 rpm .... which surprised him .
If I were to lock the dist at 38, I'd be darned sure to get the rpms up over 3000 before I loaded the engine by letting out the clutch. But it sure idles nice there. I've never ahd cranking troubles, even with very advanced timing, but with a locked dist, one might have to have a seperate ignition switch and turn on the igntion after the enigne is already cranking.
Have fun .
Bob
Thanks Bob, I am. Building the car was the most fun, driving it is OK, but tinkering and tuning is better (although sometimes frustrating....LOL). The satisfaction from success is darn worth having a beer over !
