Hydraulic setup, right? You need to bleed the system. Sounds like you have air in it.
Also, adjust your slave cylinder so that in the clutch out position, your throw out bearing is close, but not touching the pressure plate. Set it at about .015-.020" if you can.
If you have a hydraulic throw out bearing, I'd be concerned about that leak you have coming from the bellhousing.
