Old 08-16-2009, 10:26 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Default Super T -10. Where is 1,2,3 & 4th.
I'm sure there is a guru that can answer this question.
On the drivers side of the Super T-10 transmission there are three shifter tabs. The one rearmost is Reverse. The two others tabs standing vertical on the transmission operate 1st. 2nd. 3rd. & 4th. I'm trying to clarify if my understanding is correct.
The tab closest the front when moved forward is 4th. gear, moved back past neutral is 3rd. gear. Correct?
The next tab rearward is 1st. and forward past the neutral is 2nd. Correct.
I look forward to your comments,
Arthur
