Makes sense....
First shifter cam is 4th (forward) & 3rd.
Second is 2nd (forward) and 1st.
Third is reverse.
That's the way it is on a Toploader.
Or wait.....is the middle one on a Toploader reverse? I can't remember....been awhile since I've been in one.
The front one is for sure 3rd/4th.
You can take a little wrench and move the shifter lugs each way. The one towards the rear of the transmission that clicks when you go each way would be 1st/2nd. The reverse gear actually slides back and forth on a shaft with no synchronizers, so it should be easy to feel it.
