Old 08-19-2009, 02:30 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Suggest that you look at two systems:
1) TWM with a FAST Computer - probably the highest performance in terms of Air Flow
http://www.twminduction.com/Home/Home-FR.html
http://www.fuelairspark.com/Products...s/xfi/over.asp
2) The Dynaformance System - looks just like webers, includes their own computer system
http://www.dynamicmotorsports.net/Dynaformance.htm
For a stroked 351, you might get the best results with the Dynaformance system as the smaller throttle bodies would probably be a little better matched to a motor with this displacement. With proper tuning, you should be able to get either setup to work well. Note that you have the option of electonic traction control with the TWM/FAST XFI which could be useful if rear tire spin is a problem with the combo that you are considering.
I have a TWM setup on my Cobra with a FAST XFI computer and I'm very happy with it (its on a 482 ci FE motor).
If you're interested in the TWM setup, you can find more information about it in our build thread on this forum.
ERA 753 - Final Assembly in Progress
- Fred
