Thread: 5-pin KO wheels
Old 08-20-2009, 05:16 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by strictlypersonl View Post
As far as I know, all the S/C-type wheels were 7.5" and 9.5" wide. The backspacing of the 5-pin wheels is the same as the 6-pins when you include the thickness of the adapter. Bob Lacy at Vintage is familiar with our specs.
When we use the Sunburst wheels (all 7.5" wide) in the back, we use extra-long control arms to widen the rear track for a better look. So, you must commit to your wheel width and offset if/when we build your rear suspension.
Bob - I guess the same would be true for the rear control arms if 7.5 inch S/C type wheels are used all around? I think they are all the same general backspace dimensions. Sounds like I need to figure this out quickly.
Can I also safely assume this (7.5 inch wheels in back) would provide much more room in the wheel wells for undercar exhaust?
Dan
