Originally Posted by saltshaker
who do you send a oil sample to?
Jon
I send mine to Blackstone. You can see on one of my reports down at the bottom of the page that they check if you have any coolant in your
oil (you should have none). When you send them a sample, I would tell them that you're concerned over whether there is any coolant in the
oil. If you have no coolant in the oil, and the Bar's doesn't fix the leak, then you're going to have to pull the engine. If the back right freeze plug is lightly seeping, you might be able to get by with some JB Weld on it. That's worked before (sometimes).
