Old 08-23-2009, 09:11 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Default engine dies when braking hard
here's my situation, I'm using a Holley 650 dp on a Hi-Po 289 GT-350 with a Paxton. With or without the Paxton the engine dies on heavy braking. Setting the float level lower or higher on either bowl has no effect on my problem. I've ruled out any ignition related cause. I have a wideband a/f gauge installed and can see the mixture get richer & richer as I'm braking 'till it hits 10:1 & the engine starts to die. With the Paxton disconnected I can attach hose extensions to the vent tubes, and am reasonably certain no fuel is coming up the hoses. However, I can see that the tops of the secondary butterflies have gas on them. Where could this be coming from? I didn't hit the gas hard enough for the secondaries to be moving, so I'm thinking it could not be coming from the secondary accelerator pump shooters.
any ideas ???
thanks,
Z. Ray
'65 K code Mustang
'66 Galaxie 500
