Old 08-24-2009, 10:50 AM
Mus408 Mus408 is offline
Most head gaskets have a FRONT marking on them. In this position the front coolant holes,in the gasket,will be blocked,which forces the coolant to come up thru the rear water passages in the head. There is also a square tab at the front of the gasket,which should be visible when you have the gasket in place correctly.
