Old 08-24-2009, 05:41 PM
Argess Argess is offline
Oh, by the way, you mentioned you are using a Carter pump? So am I. I wonder if the pressure is a bit high on those. I have a little fuel pressure guage on the inlet line to the carb and it sometimes reads 9.5 psi, whihc apparetnly is high. But I don't trust the guage as it also can read 6 at times, Guess I ought to replace it sometime.
