Originally Posted by saltshaker
I had the neck cut down and it is as low as possible. the thought of a thinner motor mount to drop the motor maybe 1/2" would be great...but the bottom of my bell housing is 3.5" off the ground. I could trim it like ERA does!
Jon
Funny you should mention motor mounts, I was tightening mine up yesterday. ERA uses the two bolt mounts from the 1964 Galaxie. They will fit both early two bolt blocks, and the 1965 and later four bolt blocks. I don't know about "thinner" mounts.
