Old 08-24-2009, 05:59 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by Argess View Post
Oh, by the way, you mentioned you are using a Carter pump? So am I. I wonder if the pressure is a bit high on those. I have a little fuel pressure guage on the inlet line to the carb and it sometimes reads 9.5 psi, whihc apparetnly is high. But I don't trust the guage as it also can read 6 at times, Guess I ought to replace it sometime.
the pressure starts out at 6.5 lbs and goes up from there depending on how much boost is being produced. but the fuel pressure is never more than 5 or 6 lbs. more than the boosted atmosphere pressure. So the fuel isn't, or shouldn't be, blowing the float needle open.
Z.
