Old 08-25-2009, 05:13 AM
Double Venom's Avatar
Double Venom Double Venom is offline
John,
I have found, using many different set ups that you can't beat an entirely designed system. No mixing matching. I am going to assume then that you are using the '87 Corvette MC ?
Leave the M/C and replace everything else with a matching set-up. Baer, Wildwood or the likes. The "9 & "9 works OK, but I
I'd like to see "11 & "11 or even 13".
Talk to whomever you choose tech. dept. they will confirm the M/C for you. These kits are pretty straight forward and usually come with everything you will need. The difference is truly day & night!
DV
