Old 08-25-2009, 05:53 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Default Cam Overlap effect on static compression
I have a cam with 70 degrees overlap installed at 110.5. Would you consider 70 overlap to be significant and likely have an effect on the overall compression ratio. I have a static compression of 10.5:1. I'm hoping that it would be reduced a little.
Duration@.050 is IN 226, EX 236---.600/.600 lift---351w
\Also while were on cams would it be worth shaft mounted rockers if I were to ever change cams. Exactly how is the lash done for this. I never had shaft mounted.
Thanks, Lou
