Old 08-25-2009, 08:01 PM
Argess Argess is offline
Well, I can't say that I grasp everything in that article, but I believe the following:
1/ They seem to be talking about exhaust restrictions, such as small dia tubing and sharp bends, ...basically screw-ups in aftermarket, or muffler shop fabrication.
2/ Backpressure is a much touted term for muffler shops to use when trying to convince customers to put the proper mufflr on their car vs the el-cheapo alternatives. "You'll burn your exhaust valves with no back-pressure" they say. I doubt this very much.
3/ An engine can be thought of as an air pump. Anything you can do to reduce restrictions to both the intake and exhaust is good. Not as critical in 4-strokes, 2-strokes (i.e. MX motorbikes) can use this to great advantage, but hence the narrower power band compared to a 4-stroke because you can't tune a fixed exhaust for a wide range of rpms.
Anyway, I wouldn't worry about back-pressure on your Cobra, especially if you stick to your manufacturers recommendations for an exhaust system.
