Not sure about your CR wheel wells but if you like the 15x8 w/245/60 and they fit well then stay with that combo or go down to a 235/60.......on the rear15x10 is a lot of wheel you can use the back spaceing to get an 8 inch wheel out where you want it but i would stick with the 275/60 even if you go with the 10 inch wheel i think a 50 series tire is just to short and remember you will change the reading on your speedo if you go to a shorter tire..........
