Thread: Rocker issues!!
Old 08-28-2009, 10:43 AM
Question Do you have the right ends for rocker and lifter
RICKYB Rick do you have the right ends for the rocker and lifter? ball and cup? 5/16" and 3/8" on some, others are 5/16" and 5/16"? Do you have the right length pushrod for your setup? Do the rockers do a complete travel for 360 degrees of the camshaft without hitting the pushrod or having spring bind of the valve spring? A couple of pictures and a little more info would help. Is the camshaft solid or hydro? The pushrods are no rubbing or hitting the manifold? blueing is either a no oil problem or over stress issue. What kind of oil pressure do you have at idle and 2,000 rpms? Do you have oil coming from the rockers themself? Is there a oiling hole in the end for the roller of the rocker? Rick
