Old 08-28-2009, 02:19 PM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
The green sensor is 0 - 15 PSI (fuel pressure)
The shorter brass sensor is 0 - 100 PSI (oil pressure)
note both of the pressure gauges have a hole in the end
The longer brass sensors with out a hole in them are temperature sensors. One for oil temp and the other for water temp.
The water temp sensor goes into the intake manifold right behind the thermostat. The oil temp sensor goes in the oil pan.
Hope this helps.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
