Lines
Hey Bob,
If you use AN fittings and hard lines ,they need to be 37 degree single flare with tube ferrules and tube nuts to fit the taper of the fittings..ran mine with no problem and made a bubble flare for my british brake line fittings ( jag) No leaks...suprise...made my own pliers for extreme sharp bends at the fittings and no kinks..good luck..
