08-31-2009, 05:06 PM
IL
I had an FE install and the headers fit well on one and not that well on another. The quality seemed to be ok on both. On both cars I had to adjust the motor mounts position and increase the hole where the exhaust exits the body. The FE engine has to go just in the right spot to work. I would also use a hydraulic throwout bearing with an fe because the supplied slave cylinder brackets didn't work. All in all it was a very easy build.
High Maintenance Racing Team
Run & Gun 2003 - 2013
