Old 09-01-2009, 04:05 AM
strictlypersonl strictlypersonl is offline
The maximum tire sizes mentioned are correct unless the tire is considerably narrower than what is normally used. If the tire is wider, the maximum diameter may have to be reduced, especially in the front.
Now, a little rant...
Static ride height should have no effect on whether a tire rubs. A tire should NOT RUB over the full range of suspension movement. If it does, the tire is too large or the wheel offset is incorrect.
