Thread: Emblem removal
Old 11-30-2001, 06:45 AM
Maury Novak Maury Novak is offline
Cobra Make, Engine: Classic Roadsters, 302 (modified)
If your emblems are attached with foam adhesive tape, just use this wire and run carefully under the emblem cutting the foam. Do not pull up on the emblem. You can then remove the remaining tape from the body with your fingers and if any adhesive is left, use goo-gone. I have done this a couple of times.
Maury
