  #118 (permalink)
Old 09-01-2009, 12:21 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
FWIW, my iron block FE is within 50 lbs. of a stock Ford small block. That's from light internals, aluminum flywheel, manifold, water pump, etc. I believe an aluminum block shaves about a hundred pounds more.
So you're saying the lighter aluminum block, shaved FE might be around 50 lbs lighter than a heavier Windsor without weight saving components?
off idle drag pass, DA 750ft.
