Old 09-03-2009, 02:59 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by Argess View Post
2/ Power valves from each car were not "blown". However, they had a microscopic stamp ( number about 1/32" high...very small) on the brass piece that holds the spring that said 5.5. Don't genuine Holley Power Valves have the number on the aluminum part you put the wrench on?
no. the only number is on the back & very tiny
3/ Testing with a Mighty Vac showed operation around 3 in Hg for both valves. Mighty vac was checked against another guage and shown to be accurate.
Thank-you.
a mitty vac is not an accurate way to check. the power valve.
Now, for a light car that has a 290 adv Cam, and I am getting close to 16 in Hg with my current intial ignition timing at idle. According to what I read, shouldn't 8.5 Power Valves be a better choice? According to my 1966 Ford Manual, the twin Holley set-up used #85 PVs.
2/ If I purchase replacements, wouldn't 8.5s be a better choice?
Thank-you.
your idle vacuum is not the number to go by. What is the vacuum at cruising with a very light load, like up a slight grade ? For example, if that number is 9, then a 6.5 is what you want for a power valve rating.
also, your float level is very important. Too high can cause a multitude of problems. Be sure all the floats are set the same. A little low is much better than a little high. Unless you are on the Bonneville Salt Flats
Z. Ray
'65 K code Mustang
'66 Galaxie 500
