The more I look into this the more I get confused.
I am running webers, small block, there are 2 port holes; one next to the distributor, one behind. I was told to pick up a 90* shut off valve and install one of the heater lines behind the T. housing(as in the above picture), the water temp sensor behind the distributor. All is great.
The other heater hose goes to the bottom water pump nipple. no problem. My recovery tank goes to the nipple off the thermostat housing or off the pump? not sure. This still leaves me with a nipple and no hose to attach it too.
in short; 2 nipples off the pump' one off the thermostat housing and if I install the 90* I have another opening. Is it possible the nipple coming off the thermostat housing replaces the need to mount the hose off the Intake manifold?
Additionally I have 2 smaller tubes coming off the Harrison tank. One looks like it gets fed back to the radiator the other?
After reviewing almost all of the threads on this I'm glad I am not the only one. HELP
Reason: addtional info
