Thread: TKO600 clutch
Old 09-07-2009, 05:22 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Default TKO600 clutch
This is the second time this has happened.
The last time the symptom was difficulty in getting a disengagement to go in reverse, and some travel problems 1st to 2nd. At first I thought the floor mat was bunching up under the brake and clutch (which it was, once). Scott found out was an adjustment in the clutch itself.
Today it's back - I got caught in 2nd with no disengagement when I pushed the pedal. Then I managed to force it into reverse and after that it went for one or two shift cycles and went back again. I pumped the pedal and it seemed to come back. I checked the fluid and it seems full...
I'm sure we'll be able to adjust the turnbuckle-threaded rod again, but it's a concern that it has happened twice, second time in <1000 miles.
Any suggestions or areas that I should look at?
