Thread: TKO600 clutch
Old 09-08-2009, 09:48 AM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
If you have an aluminum flywheel, you should check the pressure plate bolts. Especially if they are ARP bolts. The ARP clutch bolts are not long enough and the threads in the pressure plate are recessed down into the flywheel. Bottom line, there is very little thread holding the pressure plate. You can check and tighten the bolts through the clutch fork hole. Better yet you can change the bolts. I know of at least three of our customer that have had this problem...
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
