Old 11-30-2001, 10:08 PM
RickLee's Avatar
RickLee RickLee is offline
Default Aluminum Heads
Frank
I purchased the Edelbrock Aluminum heads (Bare) part # 6008 over the bolt on ready to go set up #6006
I had heard from a few builders that the Edelbrock factory valve work, left alot to be desired. The Springs and keepers were not exactly what I was looking for either. I wanted Medium riser valves too instead of the low riser set that comes with the completed #6006 assembly.
I am just putting together my stroked 66 427 sideoiler (454) Alum Flywheel ,JE forged Pistons @ 10:7 CR, Eagle Rods, Aluminum Heads with Ferea valves with CS stainless rocker assembly with Billet end stands and Edelbrock RPM intake with a 830 cfm Holley chokeless race carb. So far it just looks pretty, I'll let you know how it runs in a couple of weeks.
I suggest you call George Gessford. He has alot of experience with these heads.
Rick Lee
