  #911 (permalink)
Old 09-08-2009, 11:15 AM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Originally Posted by cdnus View Post
David,
From what I can see in the photo, it appears that the machining pattern has a variation in tool path. If my observation is correct, Is there a mechanical reason for that or is it purely for aesthetics?
I have often heard creators of masterpieces like this state "When I built this I built two---The First & The Last" will there be others & who gets the prototype ??
Craig
The size of the squares change as you move up the picture (they are getting bigger). Surfcam changes the tool paths depending upon the size of the pocket and the size of the end mill cutting the aluminum. Many tool paths were chosen for aesthetic reasons, others for mechanical reasons, and others simply came out that way. On the tunnel, they just came out that way.
The car is extremely expensive to build. If someone wanted another one, we could build it. The prototype is here in the shop. I will put a motor back in it soon and drive the wheels off it.
David
