Thread: TKO600 clutch
Old 09-09-2009, 01:30 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Sure enough, those threads inside the aluminum flywheel start about 7mm deep inside the hole. So not much thread left. The 5/16 bolts seem a little bit skinny to me , so I will replace them with longer ones.
How long can they be? Will they stick out behind the flywheel or are those holes cul de sac?
Nothing sounds better than a Cobra in a Tunnel !
