Thread: Water lines
Old 12-01-2001, 12:31 AM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
Hopefully you aren't talking about radiator hoses! (Sorry, I couldn't resist). Are you running a heater?? The stock set up, ie, with a heater, has 5 hoses:
1: Upper Radiator
2: Lower Radiator
3: Bypass. This is a short, straight hose that goes from the manifold to the back of the water pump. A piece of 5/8" hose about 2.25" long.
4: Heater inlet. Comes off of the nipple on the water pump.
5: Heater Outlet. Comes off of an 'L' fitting on the front of the manifold, close to where the inlet is. If you don't run a heater, block off the manifold with a 1/2" NPT plug. The water pump inlet is a good place to put a fitting to pressure fill the coolant system.
I hope this helps...RS
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
