Originally Posted by Great Asp
I am yanking the transmission out this winter to replace the clutch to_______________ what can you wonder guys recommend?
Touch base with Brent Lykins. I went with the Centerforce DF with the Centerforce aluminum flywheel and the 26 spline disk for the TKO. It works very, very well... but Brent tells me I dropped about $500 more than I needed to.
This has actually been one of the better threads thanks to Tom Kirkham bird-dogging the McCleod flywheel issue. There are threads all the time talking about aluminum flywheels and, up until now, I was under the assumption that, even though some cost more, they were all about equal and had the same specs. That is apparently not the case.
