Originally Posted by patrickt
They provided their own fasteners? Do you happen to remember whether they were shouldered bolts? From the factory, did Ford PPs come with washers under the PP bolts?
Yes, they supplied 5/16"-18, 3/4" in length, no shoulders. Steve Christ's rebuild book references bolts and lock washers in the clutch reassembly process.
I'm betting that, for them to provide you with PP bolts and to specify that you NOT use washers, those bolts not only are not shouldered, but probably have dubious thread depth as well. The only way you'll know for sure is to pull one of them out and look at it.
I removed one and it appears that the bolt was threaded into the flywheel a tad under 1/2". All six of them very tight when I checked them. I think changing bolts is a bit of overkill for my street application but what would be the ideal bolt??
