Originally Posted by 67FEfastback
On my stang, then engine sits lower than stock (TCP Motor mounts), which is great for handling, and great for air cleaner clearance but the cobra tee pan sits very low. Too low to add an aftermarket rack and pinion steering system.
I know a lot of cobras use a dry sump system. Who are good suppliers to speak to about pans etc?
You cannot beat a Dailey, I have one and it pulls 13" of vacuum! The Aviad stuff is period correct but nowhere as good functionally. I have #16 lines on both feed and return and (the best part) my FE does not leak when the engine is running. When stopped it is like an old Harley though, since there is no vacuum. I am also using a Stephs pan and Steph's 16 qt tank, I do not know about the Dailey pan but the pictures look good.
