In every panel we could, we milled the sheet metal directly into the part. The made the assembly stiffer, lighter, and stronger. In this closeup you can see we milled out the entire area between the bosses that receive the bolts to lighten the part as much as possible. The wall thickness of the bosses is identical to the wall thickness of the edge of the panel, 1/4 inch.
