  #63 (permalink)
Old 09-13-2009, 02:56 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by bermblaster41 View Post
Where would the resrtctors be for the top end. The back of my block is tapped for threaded plugs but in the lifter galley I have the press in plugs. Berm
pull the plugs at the back, this should reveal if there any restrictors i believe, somebody will correct me if wrong. there might be another set of plugs inside of these, not sure. these will either be restrictors or plain plugs. i wouldn't run restrictors, your top end needs all the oil it can get, springs and lifters both. although it will effect overall oil pressure, especially at idle, best to check with your engine builder also.
