Old 09-14-2009, 01:48 PM
TWOOD TWOOD is offline
Cobra Make, Engine: Classic Roadster II, 351 windsor, Tremmec T-5
Default New seal installed
The ¾" bulb weather strip solved my "gap problem" around the top and side of the trunk deck. However, it was too large and would not compress enough along the bottom. So I used the original rubber seal from CRII across the bottom and just up ton the top of lower corner radii. I "spliced" the smaller bulb into the larger bulb by inserting one into the ID of the other. I posted three photos in my gallery to show the two seals side by side, how I cut them to make a "splice", and a view of how it looked when finished.
Anyone in need of some of the ¾" bulb rubber seal from J.C. Whitney?
I have @ 15'6" of it left over from the 25 feet I had to buy as the minimum.
Let me know.
