Old 09-15-2009, 02:59 AM
Default Need more info on the trans Ray
Hray Ray could you get a picture of the trans in your pictures? It depends on the trans, some take 75-90 gear oil like in the rearend of old cars. Some take a auto trans fluid like in new car with automatic. The best thing is to find out what trans you have and get the CORRECT weight of fluid for the trans. You might want to look at a high quality fluid like Amsoil or the Purple line. They are for higher temp running and last longer in most cases. If it's a T5 or TKO trans talk to Brent on the CORRECT fluid for them. They have changed either the weight or fluid to be used for max durability and long life. Both my trans use Full Sythesic Amsoil in the 75-90 wieght Rick L.
