Old 09-16-2009, 11:49 AM
Argess Argess is offline
I have no idea why you want to do this, but:
You can use a stud vs a bolt...make it longer than normal so the nut goes down and leaves some exposed stud. Then fasten on whatever you want.
Do you use a windage tray? They're easy to drill and add a stud or whatever.
I'vs tapped many a bolt head for a small machine screw so I can fasten other things to them. Not sure I'd want to do that on a main cap bolt.
