Originally Posted by David Kirkham
It is no problem to make the 1/2 shafts fit an original car. You will need to change the flanges to a 6 bolt pattern, but that is not a big deal. There is really no way to convert the 4 bolt flange of the original car to the 6 bolt flange of the CV joint.
We are using the Porsche 930 108 mm joints.
The 1/2 shafts are $1500 for the set, including bolts.
David
David Thank you,
The price is reasonable and those joints are the best. I was going to convert my stub shafts to 30 spline anyway, are the 30 spline shafts made with a 6 bolt flange? I am assuming that you also have a splined outer flange that will fit my hub carrier drive hub that is also 6 bolt? Will the Porsche CV clear the original circular hole in the frame and is there an issue with driving and torquing the CV mounting bolts on car? It is very difficult to get torque on the standard 4 bolt flange because of minimal clearance.
