  #1002 (permalink)
Old 09-16-2009, 09:43 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Originally Posted by Cobra #3170 View Post
David Thank you,
The price is reasonable and those joints are the best. I was going to convert my stub shafts to 30 spline anyway, are the 30 spline shafts made with a 6 bolt flange? I am assuming that you also have a splined outer flange that will fit my hub carrier drive hub that is also 6 bolt? Will the Porsche CV clear the original circular hole in the frame and is there an issue with driving and torquing the CV mounting bolts on car? It is very difficult to get torque on the standard 4 bolt flange because of minimal clearance.
There is adequate clearance to tighten the bolts and everything clears. Yes, we will supply a 6 bolt flange for your rear upright.
If you are changing to the 30 spline axles, (which I totally recommend!) then we should look into making the axle and the flange in 1 piece for maximum strength out of 17-4. That is the alloy we used on this Billet Chassis Car. Making the flange and axle in 1 piece will also allow us to make the axle as long as possible to reduce the angularity of the CVs. The part is a little more expensive, but it is vastly superior because you don't have to worry about the differential axle nut loosening (there isn't one).
David
